table saw router station
8 Users
bbn
 bbn
(@bbn)
Re: table saw router station
It would really depend on how wide the plate would be Workbench. I used 6 mm plate before but the span was too wide so there was some sag. Eventually, I just replaced the top with a solid one, no plate. A 150 mm diameter hole covered with 12 mm thick acrylic plate should be fine but you'd loose a lot of cutting depth. Best to keep it at 6 mm with as small a hole as practical.
Phenolic is solid material but it tends to chip unlike aluminum. Best would be an aluminum plate with a lift :).
Posted : 04/05/2010 10:44 am
(@rolly)
http://www.amazon.com/MLCS-9334-4-Inch-Aluminum-Router/dp/B000VS8B0M/ref=sr_1_1?ie=UTF8&s=hi&qid=1272809431&sr=1-1
i got this instead 🙂
so bee, ur no longer getting a diy plate?
ako i got this rousseau plate from amazon, kaso isinuksok nung kaibigan ko sa balikbayan box, instead of bringing it home with him this week. . . end of june pa dating dito, bad trip. . .
kaya im still on the lookout for a tempo plate, until that arrives, meron na ako very amateur router table awaiiting for a plate, hehe
Posted : 06/05/2010 6:09 pm
same here. nilagay sa balikbayan box hahahah
june pa din darating.
I used a bamboo chopping board for now 🙂 the alum plate is too expensive
Posted : 06/05/2010 9:27 pm
hindi kaya na iisa lang ang friends nyo? hahahaha
Posted : 06/05/2010 10:43 pm
this is my very first router plate, made from 1/4" thick aluminum plate...
with my very first fence...
and my very first dovetail jig, which I made and worked....
and yes, my first real router was a Maktec...
Posted : 06/05/2010 11:12 pm
Wow ... Timber you've come a long way now.
Pinnacle Aluminum Plate, Leigh Super Jig, Triton and a Big Boy Makita Routers and most importantly the skill level improvements that come with quality tools at the hands of a craftsman. 🙂
Posted : 06/05/2010 11:51 pm
thanks Jay for the vote of confidence, but you know what, the Maktec worked fine when I had it, my only concern was heat, not very hot, but hot. and while that jig looks crude (dahil homemade lang kasi) it worked and I was able to do dovetailed boxes with it and a local dovetail bit...
Posted : 07/05/2010 12:23 am
(@rolly)
hanep!!!!!!!
Posted : 07/05/2010 7:15 am
Timber,
Do you still have that alum plate?
Posted : 07/05/2010 8:24 am
Timber,
nope, sold the whole thing, router table and all... 🙂
Posted : 07/05/2010 12:51 pm
(@rolly)
got a plate from t alonzo, store near corner of ongpin and alonzo. just need to have the hole in the middle done
Posted : 07/05/2010 2:31 pm
Tired from work so i improved whats underneath my table saw and router table for my R and R....
best drawer alignment i have ever made!
this was how it was before.. well sort off... plus wheels 🙂
Posted : 26/05/2010 11:00 pm
saves me from running back and forth when changing bits
i forgot to cover the underneath of the ts (with some sort of way to redirect saw dust) coz its all collecting in the drawer hahahahah
Posted : 30/05/2010 4:17 pm
i also took out the wheels since the rubber caster wheels were cracking. I never moved this anymore anyway
Posted : 30/05/2010 4:50 pm
That's a neat time saving idea.
RT plate still in transit Bee?
Posted : 30/05/2010 5:56 pm
Page 3 / 4
