table saw router station
8 Users
Re: table saw router station
yes it is still in transit huhuhu the bamboo chopping board is thicker than a 3/4 ply.. hence i lose alot of height
Posted : 30/05/2010 6:11 pm
nice router bit tray, use to have as much, but running out of space for the bits... so I am making the new rt with lots of bit space...
Posted : 30/05/2010 10:19 pm
I'm surprised your going back to a bigger RT table or you're going to have two.
Posted : 30/05/2010 10:39 pm
not sure yet if I will keep both, the current rt is portable and the stand will be dedicated to the thicknesser. that is why I decided to build another full sized one...
Posted : 30/05/2010 10:45 pm
i suspect mine is a temporary solution. Hence those trays are not glued nor screwed. Its just tucked in. Its a pretty tight fit thought
once i get my rt plate i may make a dedicated router table. copying you new build 🙂
I shall be anticipating you Thicknesser sled as well 🙂
Posted : 30/05/2010 11:22 pm
Ben I have the complete plans deluxe router table by Norm Abrams, I just modified it to fit my space... I can burn you a copy if you like... very nice and complete plan, also comes with a video...
Posted : 30/05/2010 11:25 pm
Hi Timber,
sorry i only saw your post just now.
I miss out on new posts if the new posts exceeds the amount that can be displayed in the window in the lower left.
I would be great to have that plan 🙂 i really appreciate it, thanks!
Posted : 24/06/2010 1:42 pm
ok right now its not a router station YET.. will attach it again in awhile when i add supports on the left side
the crosscut sled would be something Macduff may want to use since its slap on and take out quite quickly. It rides on two references. The Fence and the left edge of the jimmy jig. I used acrylic 1/4" since plywood 1/4 is too flimsy.
Interestingly enough i have the exact same cutting capacity coz before i used a 3/4 ply for the sled. Now its 1/2" from the jimmy jig and 1/4 from the ply which is exactly 3/4 ehehhehe
and as you can see some really quick and dirty work on the panic stop... the frame wherein the hinge of the panic stop is attached is double sided taped on to the shell of the TS 🙂 hehehe
Posted : 24/06/2010 1:48 pm
Page 4 / 4
