What tools do i need?
7 Users
Re: What tools do i need?
laminated plywood sa loob ng cabinet with raised panel door, hardwood mga furniture. gts 10 yung table saw.
40 and 80 tct teeth?
for general use I recommend a 40 tooth blade middle ground yan ng ripping and cross-cutting. the 40 tooth blade will in itself provide you a clean cut already and can be used well for ripping. I use a D1040X Freud (thin kerf) blade and very happy with it cutting hardwood and sheet goods.
an 80 tooth blade will give you a very clean cut on plywood but it will also make the cut much slower mostly designed for cutting other stuff like soft metals and plastic yan (but not always).
If you can afford to get the highend blades like a Freud Fussion (P410) or a Forrest Woodworker II, these come highly recommended and considered the standard in quality cuts.
Posted : 12/09/2011 1:24 pm
(@software)
Thanks bro, i will get a 40 and 60 tct teeth blade. Dami akong nakita ditong CMT Orange na 30mm yung bore. yung mga freud malalaki yung mga bore.
Posted : 12/09/2011 2:17 pm
nasaan ka ba? the GTS10 I have come across uses 5/8" spindle, the freud blades fit perfect on them. Ano ba spindle size ng ts mo or arbor size that you need? best physically check the blade arbor size first.
Posted : 12/09/2011 2:33 pm
(@software)
dito sa KSA, yung arbor size ay 30mm according to manual, hindi ko nakita ng actual pinadala ko na. malalaki yung arbor ng freud dito para sa industrial cutter.
Posted : 12/09/2011 2:50 pm
(@zepol)
thin na ba ang 116? gee mebbe i rememberd wrong. my kerf was quite wide.
Posted : 12/09/2011 5:35 pm
(@bigfoot2)
The GTS10 has different arbor size depending on the country to which they are sold I think.
Posted : 12/09/2011 8:43 pm
(@software)
thanks for the info.
Posted : 12/09/2011 8:58 pm
