Where to buy a good Bandsaw
13 Users
Re: Where to buy a good Bandsaw
update on the sbw 1401n of OAV with riser block,
Vic's construction (where i got my table saw, and my Dad knows the owers, but i never liked name dropping anyways) according to OAV will contact me soon because they will have anothe order of equipments.
I might get this one kung ok price, this will be my resaw saw lalalalala
Posted : 16/02/2011 10:57 am
this is the email i got from vic's construction!!
1 unit bandsaw machine
model : SW-1404 with Riser block Php.27,000.00
60 to 75 days from order
Regards
che
KAKAGAT NA AKO!!!!!!!!! may 2 months to save pa naman eh
Anybody else wants to buy?
Posted : 16/02/2011 2:03 pm
Regards
che
do they say what the cutting capacity is Ben? I might get one if the cut is to my liking... 😀
Posted : 16/02/2011 2:13 pm
Man! You guys must have very understanding SWMBOs for you to get away these major expenses!
[COLOR="Lime"](green with envy)
Posted : 16/02/2011 3:38 pm
ahhhh naitatago ko naman kasi yung mga tools ko eh.. she hardly goes to the basement hehehe
and come to think of it, i am actually kinda broke na rin.... ahhaaha... unexpected expenses popped up.. jeez
Posted : 16/02/2011 3:52 pm
finally a rolling platform
this bandsaw is indeed handsome
bandsaw is two speed, I havent really read the manual.... the manual is.. ummm.. really bad
Posted : 16/02/2011 11:21 pm
(@rolly)
pwede rin ba sa metals yan bee?
Posted : 16/02/2011 11:23 pm
the table tilt mechanism is positioned way at the back, mainly in the outfeed area, so tilting the table is kind of awkward. Also the tightening mechanism is that black knob, and its only one.
The table WILL pivot left to right if coaxed but will NOT tilt. Hence a fence can be thrown out of alignment, I am sure there is a way to make this more rigid. But rest assured since it dont tilt when fixed into position, hence all cuts will be squared on
bearing guides, i think they are carbon, I will let t he pictures describe themselves
bottom bearing guide
Posted : 16/02/2011 11:27 pm
NOw here is the upper wheel, When i tested the co-planarity of the wheels, the lower wheel was out towards the infeed side by half an inch more than the upper wheel, You see those 4 bolts? they hold that rectagular plate that holds the pillowblock of the upper wheel. I took out those bolts then shimmed it with washers BEHIND the plate, Worked perfect
this adjusts the tracking of the upper wheel. Tracking is where you adjust the tilt of the wheel in order to have the blade resting in the center. Only adjust when blade is already tensioned.
lower wheel, it cant be tracked ( i think its the same for all) and co-planarity cant be adjusted, but in my case it didnt matter
See the brush? its essential to keep the rubber on the wheels clean, i will be upgrading this
There is a lever on the right side to loosen that rotationg cylindrical thing in order to change the speed setting....
fence can be adjusted for drift angle
Posted : 16/02/2011 11:33 pm
this is under the left hand side of the table (infeed orientation) This is like the stops in a table saw, This one is for 0 degrees. I dont think there is a stop for 45 degrees
both top and bottom wheel compartments have this, Its a safety release button thingymajig. Basically it keeps the bandsaw from powering up if the compartments are open
Posted : 16/02/2011 11:35 pm
Yup pwede, just change the blades 🙂 according to the store
Ang hindi ko lang alam is if 1hp is good enough for metals. I mean i think it will cut, but with how much effort i dont know...
with wood its quite effortless
Posted : 16/02/2011 11:37 pm
oooops
mali yung pinost ko na review
I transferred it to the proper thread. Wow this new forum allows you to delete message
Posted : 16/02/2011 11:43 pm
(green with envy)
that's easy... first I work hard and save up extra to buy my tools, then I make something for the house or for her... then I try to market my stuff to earn some more extra to fund my next purchase...
what is difficult is your username, do you have a nickname? 😀
Posted : 17/02/2011 12:57 am
hehehehe 🙂
Posted : 17/02/2011 5:15 pm
ill include this question here as well
Where do we get Good Bandsaw Blades?
iam currently in need of a 1/4 wide blade which elektrowerks dont have, they only have a 3/8 blade.
Posted : 17/02/2011 5:19 pm
Page 7 / 8
