MDF Boards Projects
70 Users
Re: MDF Boards Projects
@timber,
are there available bottom mounted blum glides as well?
yup, mounted at the bottom center of cabinets, though not sure kung blumotion din. Gives you a traditional look na walang hardware...:piano:
Posted : 10/06/2011 12:58 pm
What's the joinery used for these laminated MDF?
mahirap ng konti joinery nya Jun, mix ng dovetail at finger joint...:eek:
butt joints lang with special fasteners starting with confirmat screws :bounce1::bounce1::bounce1:
Posted : 10/06/2011 1:00 pm
@Violane
Blum Distributor (Philippines)
DEEPE Marketing Corporation
No. 13 Bonifacio Drive, Pasong Tamo
Quezon City 1107 Philippines
Telephone no. : (632) 952 - 9854
Papasok ka ng Tierra Pura Subd, sa may Tandang Sora.
There's a hot melt glue na ginagamit sa PVC edge band but intended for edge banding machine.
Posted : 10/06/2011 11:55 pm
bryant,
naiiba ka for a DIY'r...mdf for a projects....:chopper:
hope you post all your mdf projects, to give us all your galleries of ideas about mdf...:bokmal:
Posted : 11/06/2011 6:41 am
Study Table w/ drawer just finished recently.
Posted : 11/06/2011 5:48 pm
I just found out that I have some pieces of Blum Full Overlap Hinges lying around and took some pic together with an ordinary full overlap hinge. Noticable differences. This Blum Hinges cost P275/pc no add-on blumotion, ordinary full overlap hinge cost only P22/pc.
LID Stay, Gas Lift, 120N.
I use it on overhead cabinet with door open upwards.
Posted : 11/06/2011 5:58 pm
I now have to ask Bryant, what screws did you use for these joints?:smshocked:
Posted : 11/06/2011 10:13 pm
@Timb
I'm using Hi-Lo Screw 45mm, need to pre-drill the MDF throughout the length of the screw to avoid splitting plus countersunk center bit 8mm x 3mm to flush the screw head. Then put plastic cover caps (for Hi-Lo Screw) to hide the screw head. Confirmat screw can also be used.
Those screw & cover caps are available at Tu Soy.
Posted : 12/06/2011 7:24 am
are there blanket/toy chest stay hinges made by blum?
i have been for months now eyeing on the rockler stay hinges for this purpose.
Posted : 12/06/2011 7:08 pm
post a link of the item in question brader... I think Hafele has them... maybe I have them too:oops2::oops2::oops2:
Posted : 12/06/2011 7:31 pm
galeng bryant..hats-off para sa mga projects mo.
Posted : 13/06/2011 9:06 pm
ei..mali pala product name...lid-stay torsion hinge pala.:confused:
http://www.rockler.com/product.cfm?page=21288
Posted : 13/06/2011 9:44 pm
text mo ko bukas about this so I will remember to take a picture of what I have on hand....:secret:
Posted : 14/06/2011 1:03 am
Closet Proposed Design vs. Actual (after installation).
Posted : 19/06/2011 8:51 pm
Closet Design at Master Bedroom.
Color: Dark Apple Tree
Accent Laminate : Abstract by Greenlam Laminates
Posted : 19/06/2011 9:17 pm
Page 2 / 17
