Re: MORRIS CHAIR, building a classic.
Sorry for the ignorance, could you somehow rephrase it again? My virtual router is having problems with this method ๐
sige, let me rephrase it....
get a piece of stick with a 1" x 1" x 12" (it can be any depending on the roundover bit, will be using 1/2" roundover bit for example).
now, start rounding over the piece 1 or 2" from the front end and stop 1 or 2" from the end. then roundover the other 3 sides the same way.
you will end up with a dowel that should be 1" in diameter with square stocks at the ends, this you can cut off to get the dowels...
using this method should be safer than rounding the stock all around since it can grab the stock and you would have no control over it without the ends.
intiendez? ๐ฎ
๐ ๐
^ ah ok, so it would look like a miniature dumbell ๐ Thanks timber, I got it this time!
is the dowel also yakal? looking good jon...this project is really consuming you and i bet there are still good projects for you waiting in line. hehe
my incra is still inside the box...can i buy time?
I suspect there was a secret blood transfusion from Timber to Jon. Its manifesting on the quality of Jonathan's work, 90% Timber.
I guess Jonathan's new blood type is B...Bosch... :p
Peace!!!
on my way to work na bro, yes the dowel is also yakal, since i want it to be strong, yakal is the best choice.
planing to build 3 of this chair, 1 for my son, and 2 for my 2 daughters, ha ha ha! sana nga
magawa ko, sa dami ng projects in line...:p :p :p
Peace!!!
thanks bro, on my way to work na !!!
Looking good Jonathan canโt wait for the finish product. Just want to share my Morris chair and hope it will give you an idea on the upholsters side. Finish using alcohol base stain.
ganda naman chisel.. that is one fine woodworking project...
so ganito pala ang morris chair...can't wait to see na rin jonathan's.
questions lang chisel, what type of wood did you use on this and did you put sanding sealer before or after the stain? TIA.
Not my project bought them in sets. He,he,he ...!:)!..
Galing talaga Sir!!
this is the tricky part of the building process, doing the curved BACK SLATS, in doing so, i made a
scooping jig to make the woodblocks looked curved.
you can curved cuts on a woodblanks with a bandsaw, or a scrolsaw, but ain't got any, so hope
this jig will do wonders
Doing great jonathan specially with your jigs! This one (jig) must have been a pain to set-up. Bit depth and position of the stock should be right-on to achieve the result you got. When the saw dust flew you must have been wishing for a bandsaw;) hehe Cheers!
there several ways to skin a cat, using ski's and that jig works fine, a bandsaw would be easier, and a portable grinder can do that too. in my case, I would probably make a template and cut the curve using a handheld router with a long pattern and template bits, Moji would probably use a spokeshave ๐ ... there is no limit to what and how things can be done. important is to get there safe ๐
I'd have probably tried to steam-bend it (and broke it in the process).
ohh!! there are many styles of morris chairs, many modifications, but the straight lines, typical
of a morris chair is still there.
mine is GREGORY PAOLINI inspired, but without the bowed -arm.
i'm planning to build the upholstery myself with swmbo's touch, if time permits.
that's what i love about morris chair, napaka simple.
thanks chisel.
